Celik28
New Member
I own a volvo penta tamd71a. I have two problems. Firstly, when the engine does not run for 3-5 days in winter cold, the first starter also works with difficulty. After pressing and releasing the starter, the engine turns and misfires many times. At that moment or in the same day, when I stop and start again, it starts instantly. The second problem is that when I do full throttle from idle, there is a slight acceleration of 2000rpm, but then it stalls, even though the engine is at full throttle, it suddenly goes up to 2500 after 3-5 seconds. That is, it eats gas by itself. I talked to two different authorized services. They said it's the same. I think it's usually the same problem with volvos. I wonder if any of you had a similar problem?
