volvo penta tamd 73p edc,ecu problem.
cataldo
26 Aug 2004
donegal ireland
the ecu for one of my tamd 73p edc engines is giving an 8.3 diagnostic fault reading and will not clear, any ideas,can they repaired ,thanks. <span style="color:red"> </span>
the manual says:-
Code 8.3 Calibration
Cause: The calibration values cannot be stored by the
control module.
Consequence: The control must be calibrated before each
start.
Corrective action:
• Erase the diagnostic trouble code (DTC).
• Recalibrate the control.
• Contact an authorized workshop if the fault persists.
Sounds like it might need a volvo engineer and his laptop.
No recon units are available. no surprises that volvo hold all the cards !! I had a faulty ecu replaced on a kad 44 two years ago and the only option was a new one which then had to be programmed up by the local dealer. cost about £1500 to £1800 from memory. Good luck
Does the boat run OK? My starboard engine light has been flashing last 12 months, the code shows a temp sensor fault, but its been checked out and is OK. The VP dealer can't clear the fault light.
no it wont start and i have tried it on the other engine and it won't work on it either, it seems dead.are they serviceable units or do they have to be replaced.
