rszemeti
Possibly not.
I like to use mineral oil with vds3 spec listed on the specification.
Well, if you choose to ignore Volvo's advice, that is up to you.
Possibly not.
I'm not - that's the correct spec for my engine .Well, if you choose to ignore Volvo's advice, that is up to you.
......... with the older VDS3 and Volvo recommend that you use the later specifications in preference to the older spec.
Its surprising many dont even consider using the search facility all 3 above take up zillions of bytesI love these "oil" threads ..... even more than "anchors" or "Colregs".
Richard
In that case why do Volvo Penta still supply engine oil labelled as 15w40 VDS 3 ?
Because they enjoy the extra profits selling low grade oil to gullible people?
So you previous statement was meant to be a joke?Because they enjoy the extra profits selling low grade oil to gullible people?
If you look at the catalogues of any major oil producer you will see that they produce a huge range, some first introduced many years ago. For example, it is not all that long since Shell discontinued API CA for one specific engine. If later versions are superior and totally interchangeable why would they continue to make them? There are no extra profits in small batches, just the opposite.
If you haven’t made the move to Volvo VDS-4.5 Engine Oil yet, there’s no better time than the present. Not only is this leading-edge oil – first introduced in 2016 – our factory fill, but it’s also growing in popularity throughout the aftermarket. Here are a few reasons why.
Compared to older American Petroleum Institute (API) CJ-4 engine oils, Volvo VDS-4.5 delivers:
20 percent better wear protection
50 percent higher oxidation resistance
80 percent better high-temperature viscosity control
Volvo VDS-4.5 is backward compatible, which means it can be introduced as a direct replacement wherever VDS-4.0 or API CJ-4 oils are used.
You now seem less certain .If you dig through, you will find that you can use a VDS4 wherever you can use a VDS 3 ... ...
Lets be clear. VP don't recommend using vds4 instead of vds3.
But they may imply somewhere the later oil may be used.
I will stick with vds3.
If you dig through, you will find that you can use a VDS4 wherever you can use a VDS 3 ... ad note is says "wherever VDS-4.0 or API CJ-4 oils are used. " not "wherever VDS-4.0 or API CJ-4 oils are specified" .. hence if you are using a VDS 4, in place of a VDS 3, there is no reason not to use a VDS4.5
Same applies to the CG - CH -CI -CJ - CK series ... read the spec, they explicitly state they are backwards compatible ...
In particular, the improved chemical stability of the later oils, lower moisture absorbtion, reduced acidification would all be beneficial in a marine enviroment.
Improved chemical stability is a high temperature property, not applicable in a yacht auxiliary. Lower moisture absorption simply means that the water will instead be free in the sump. Unless you have some means of draining it off there is little benefit. Reduced acidification means higher TBN or a different technology, desirable in a hot engine but can lead to increased bore wear in a cool running engine.
There are good reasons why oil manufacturers design oils for different duties.
