I'm helping a friend with changing cylinder heads and cylinders blocks on a VP MD2. I have experience from rebuilding an MD11D and on this latter engine shims are used below the cylinder blocks to get an accurate height between the piston top and the cylinder head. The MD11D however, has seperat(wet) cylinder liners which the MD2 has not. Is there a standard cylinder bottom gasket with a fixed thickness to be used on the MD2 or is the piston height controlled by shims in the same manner as on the MD11C/D?
Olav
Olav
