Tranona
http://www.volvopenta.com/SiteColle...lish/Marine Commercial Rating Definitions.pdf
The link is to Volvo Penta's ratings system which includes R5 which is their Pleasure Duty. This specifies full power being used for 1 hour in twelve.
https://pubs.volvopenta.com/ProdDocs/Home/Disclaimer?publication=47709049&lang=en-US
The above link is to the specifications for a D2-40 which is rated for R5 use.
A Formula 1 engine is designed to produce very high output for a very short period so that engine life is very short. The same engine used to drive a pleasure boat, if used to drive a generator would have an unacceptably short life with the pleasure boat power output. To increase engine life output is reduced. The various types of vessel being driven by the engine require different engine life. A cargo vessel engine would be expected to perform for many years at full output with limited maintenance. The pleasure boat, at the other end of the scale may run for a few thousand hours only before requiring extensive overhaul, but the owner would achieve those hours over many years and be happy to accept a more stressed engine as it costs less and takes less space.
As i suggested all this is irrelevant for the sort of engines and applications being discussed here. These engines are very low stressed - The D2 40 has a specific output of approx 26hp/litre, about one third of the specific output of even the most basic auto diesel. The R5 rating suggests it can be used for a planing boat - can't imagine what sort of boat would plane with 37hp inboard!
Contrary to what you suggest small yacht engines are very lightly stressed as they are derived from low output industrial engines that run at high loads for long periods of time, such as generators or small construction machines which typically run 8-10 hours a day non stop. So engines have an easy life in a yacht - in fact the biggest problem is owners do not run them long enough or hard enough, then leave them unused for weeks on end! Heavily used engines such as those in charter boats or small commercial boats easily clock up 10000 hours+ without any problems.
The 1 hour in 12 full power use is irrelevant because in a low speed displacement boat you rarely need to run above around 70% power (approx 2200 rpm on a D1 40) as this usually (if the prop is correctly specified) gives a cruising speed of around 80% of maximum. Achieving that last 20% doubles fuel consumption and is noisy and uncomfortable.
