Volvo Penta Heat Exchanger corrosion poll - please help
Jmc1764
17 May 2020
Gillingham Medway
Here it is: Wide collection Boat Exhaust systems at VETUS boat parts
The flange that corrodes away is this one here circled in green, and my Bavs set up is identical to the below:
So, hot engine, turned off, hot water vapour travels back up the exhaust, into the Heat Exchanger and condenses?
Two dissimilar metals, and now we have an electrolyte to complete the destructive equation?
Leading to:
Do we agree this is what's happening to cause this corrosion? If this is the case, what can be done to prevent it? I feel an email to Vetus coming on...
I have an old Vetus M4.14. recently replaced the exhaust elbow that was cast iron and had rotted, new one is bronze. there was a composite gasket between the cast iron elbow and the alloy heat exchanger exhaust part. no corrosion there at all, in fact it looked brand new after 30 years ! I think the gasket is the solution.
MagicalArmchair
11 Jan 2013
Kings Hill, Chatham Marina
That’s what the technical guys at Parts4Engines said. I purchased a new stainless exhaust elbow from them that they resell. It was packaged with a steel gasket by the manufacturer, however, Parts4Engines supplied their OWN composite gasket alongside, recommending I bin the metal gasket and use their composite one for the reason of protection from galvanic corrosion.
So that is the solution, however, do we agree that water has got up to that point through evaporation from the waterlock? Short of the chambers being compromised, that’s the only place it could come from isn’t it? As Vic states, there must be an electrolyte.
VicS
13 Jul 2002
I think you need to investigate how water gets there , Condensation .... Maybe? . Splashing or blown back from the injection point ?
Check that the anti siphon valve is operating properly
Check with the Vetus calculations that your watertrap is of adequate capacity.
Make sure that the exhaust elbow does not create a lip that will retain a puddle of water in the HE
Use the composite gasket
garymalmgren
28 Jan 2017
Hi Magical Armchair.
I notice that the title of this post is,
And no one has come back with another example of this type of corrosion.
In fact the only identical engine sample was Jmc1764 who said
"between the cast iron elbow and the alloy heat exchanger exhaust part. no corrosion there at all, in fact it looked brand new after 30 years !
So the answer to your original "POLL" question seems to be , one.
That raises the question , If this is supposed to be such a prevalent failure, where are the examples?
Happy New Year to all.
Gary
Jmc1764
17 May 2020
Gillingham Medway
I think the fact that the gasket covered the whole area that bolts the elbow to the exchanger, thus making a water tight seal across the whole surface, a ring or smaller gasket not covering the whole area may lead to corrosion. The new gasket was about £4 from Vetus and is made as the same composite stuff as the old one, in fact I kept the old one as it looked perfect just slightly compressed. You could probably buy a sheet of the gasket material and make your own to fit your particular engine, although you may have to do some repair on the damaged area first,
parbuckle
7 Feb 2011
If enough sea water was getting to the damaged area you may see rust corrosion around the exhaust valve area this can easily be viewed now the HE is removed you will need a mirror and torch its a bit frightening that the part cost nearly half the cost of a new engine
Spirit (of Glenans)
28 Mar 2017
Me; Nth County Dublin, Boat;Malahide
Ive answered many questions about seawater getting back to the engine (or generator) The area affected is on the bottom of the flange where it could collect. Think about this, warm seawater sitting in the water trap, not to far away from that area. Engine shut down, a nice warm salty moist environment waiting to condense there. So why does it affect some and not others? Perhaps a look at the total exhaust system. Is it possible for sea water to splash back/ condense? Vetus do a good diagram in their catalogue showing best practice. Perhaps also the elbow should be part of a planned preventative maintenance program?
Condensation from any water based solution will consist purely of H2O (distilled water).
Beneteau381
19 Nov 2019
Splash back? Also salt water atmosphere is corrosive. Hence cars by the coast, ordinary steel on our boats, they all corrode more easily, I am sure that there are cleverer folk than us that can explain it.
MagicalArmchair
11 Jan 2013
Condensation (distilled H2O) will be a perfectly viable electrolyte, so I think that’s still the favourite theory for how water reaches that area.
As for Gary’s comment that no one else has shared my heat exchanger pain on the forum, the reason I looked in the first place was partly due to horror stories on the Bavaria forums where others had the same challenge, such as the below:
Knock-on effects of heat exchanger/manifold corrosion
pvb
UK East Coast
MagicalArmchair
11 Jan 2013
The link you quoted was about heat exchanger/manifold corrosion. Isn't this a different problem?
Quite right, apologies, it was this one that alerted me:
Volvo Penta D2 55 Corrosion at Sea-Water Injection Elbow and Heat-Exchanger
It makes me grateful I don’t have the issue in the first article mind you!! The interface between the exchanger and the manifold is fine thank heavens.
Re reading the article above it put the reason for the salt water being there spray back due to the salt water inlet being partially blocked up (mine was), so this could be a more plausible reason as to the water reaching that point.
VicS
13 Jul 2002
This sounds as though it explains what is going on
The elbow is a hollow casting with 3 core plugs. Internally the cast iron corrodes as it is hot and wet and passes warm sea-water! The scabs of iron oxide build up inside the elbow. These can block the water injector ports ( one on top and one below) In this process its quite possible for pumped sea-water to spray backwards toward the exhaust manifold.
The resultant hot sea-water corrodes the aluminium all around the flange to the elbow, eventually it will leak EXHAUST GASES into the engine bay.
MikeBz
22 Aug 2005
East Anglia
@MagicalArmchair Thread revivial... Investigating a salt water leak from my MD2020D (about a teaspoon of water soon after startup, and no more after that) I found it was wet around the exhaust elbow (S/S fabricated item from Keypart) and the lower RHS stud nut was very rusty. Removed the elbow and found the weld between the tube and the flange had cracked. That was minor compared to this:
After removing the studs and brushing off the loose bits:
The yellow circle approximates to where the hole in the gasket would be.
The notch is where I've attacked it with a file to find some solid metal. I wonder if the corrosion has been exacerbated by having a S/S elbow.
I think this is may be salvageable by milling around 7-8mm off and making a 7-8mm spacer to go between the housing and the elbow. If the spacer were aluminium and had a slot to match that in the housing rather than a circular hole then that would give some protection to the face of the housing, and the spacer could be considered sacrificial in and replaced when it has corroded sufficiently.
However... despite that fact that the engine was running fine I find that turning it over by hand there is good compression on #1, some compression on #2 (hissing of escaping air), and nothing discernable on #3. I've been told that #3 is prone to this being so close to the exhaust, the valves can rust. So next job is head off.
It's a bit like renovating an old house - one minor repair and bit-by-bit you take the whole thing to pieces.
Beneteau381
19 Nov 2019
Stop attacking it! The water passage is quite close to the flange there! If you machine it you will break through. The issue with these engines is that when the elbow blocks, when the engine stops, the water migrates back in to the manifold and then attacks the valve seats. Hence the lack of compression. Its head off time and valve grinding time. Be careful!
MikeBz
22 Aug 2005
East Anglia
Yes I know there isn't much meat there, but there does appear to be enough as long as the metal is sound. Nothing lost if it breaks through as it is scrap as it stands. A new heat exchanger housing is north of £1200... I have the option of a complete used engine which needs a bottom end rebuild but apparently has a good head, heat exchanger & elbow for not much more than half the price of a new heat exchanger housing (includes alternator, starter motor etc.) so that might be a more economical route and leave me with some useful spares - subject to verifying the condition of the head/heat exchanger housing/elbow of course. Anyway, next job is to whip the head off and see what I find.
Alternative approach to the corroded HE problem (not for me thanks) - found on EBay:
Beneteau381
19 Nov 2019
Ok, there is a vid floating around the net of a German guy cutting big lumps out of an MD22 manifold and tig welding fresh aluminium in. If you are confident of your abilities this could be done to save brewsters.
Aquanaught
26 Jul 2017
The manifold on my MD2030C was corroded but looked sound untill I wire brushed it and the water passage just crumbled. My engineer thought the issue was the lack of sufficient drop from the manifold to the water trap allowing salt water to travel back to the manifold when engine off as boat pitched. Subsequently have reengined using a higher swan neck injection bend.MD 2030 Perforated exhaust.jpg
