daddycool
Hello to anyone that can help. My boat has been on dry land for 18 months and has a penta AQ211a engine that sounded nice when tested on my trailer, (for less than a minute to prevent overheat) but still would only start by spraying fuel into the carb. When I put it in the water to fully test I found it still would not start unless fuel was sprayed in to the carb, once it got going it cut out straight away below 2000 revs, also the right hand exhaust manifold was blocked.
The manifold is now clear and i have good water flow and temps, i have changed the plugs, rotor arm, dis cap and set the points. There is a good spark but the problem of starting is still there and it never ticks over.
The engine will only start by spraying fuel into the carb and the throttle has to be wide open for it to fire, when it does start it sounds awful, really bad, and then as you lower revs it cuts out.
I would really appreciate any help of where to go from here as I am now really stuck.
