gordmac
Having eventually figured out you need to lock the controls and press neutral to trim the outdrive up to the required angle (something you might think would be in the operator's manual!) and taken the filler plug out it would appear I have water in the oil. A bit annoying, particularly since the last owner paid a considerable sum to have it sent away for repair in the autumn.
Presumably I need to pressure/vacuum test to try and find how it got there, anyone recommend what to use and how to connect it? The filler plug is rather large! I take it there are seals both on the outer prop shaft and between the shafts? Seals on the gear selector? I presume if the water was getting in via the input shaft in the bellows it would also be leaking into the engine compartment?
I haven't drained it yet ( forgot to take a container to drain into with me and it is a 60 mile round trip!). How do I get the remaining emulsified oil cleaned out? Would filling with say diesel rinse it out?
Any advice gratefully received.
