Volvo Penta D4-260 A-B replacement bell housing
Castlecooley
9 Apr 2022
Can anyone tell me why the new replacement bell housing has a hole alongside the shaft which requires a plug and flange screw to be fitted?
Some volvo flywheels have got a hole in the corresponding position.
It could be there to be used as a flywheel lock if you insert a rod when lined up?
It’s for the ‘water in bellows’ sensor on the new DPI drives. They use the same bell housing as the DPH-E drive which don’t have this feature, hence it needs blocking off
