coyi
Hi All. The problem occurs on start up. Sometimes the alternator fires up and produces a charge, sometimes not. I suspected the exciter wire as very often there was less than 12volts at the D+ terminal. So I bypassed the blue/red wire and fed D+ directly from the engine control panel. Alternator fires up every time. I took off the black connection box and discovered the magnetisation resistance had heated up the attached wires and melted their insulation. What should I do and is this resistor important.
Thanks for any advice.
