Volvo Penta D12 and NMEA2000
KajLehtinen
6 Dec 2003
Sweden, Stockholm
www.sealine.nu
Hi!
Looking at adding VP's NMEA2k gateway to my Sealine T52 to get engine info to the NMEA2000 bus. I think that I need the following Volvo Penta parts, first a Y split cable #3588206 and then the gateway itself, #3889758.
Would D12 be able to use the trip computer, or is that overkill when I have it in the MFD's instead? I'e what EVC level does the D12's have?
Depends which EVC level of system you have . Early 675 Hp engine is old style analog gauges so no 2000 link .
If I send you serials, can you have a check on what level it is?
I understood it that if one is EVC-B or lower its only Engine data thats availeble, but if the engines are EVC-C or higher the trip computer will work depending on a software upgrade?
