moresparks
Hi, Quick question if I may.
I am removing my AQ171c Engine and need to ask a question regarding the Clamp Ring.
The sterndrives have been removed.
6 bolts holding the flywheel have been removed .
All hoses and electrical connections have been disconnected etc and is basically ready for the crane.
However the Clamp Ring appears to be stuck fast.
Will this come off when the crane lifts the engine backwards and then up?
Or do I have to remove the clamp ring first?
If necessary I can destroy the clamp ring by drilling holes and breaking it off, also I am not sure if there are a couple of threaded holes in the clamp ring to re-insert the flywheel bolts and "push the engine backwards.
Advice gratefully received.
