mkor
Hey guys, me and my boat just arrived in the UK and after a start and first ride the spark went out. I don't know anyone here at all. I am in the Solent, on the Humble River, on a pontoon in the middle of the river. And I really need a person who can come and read the error codes of my engine. I can take you by car and tender to the boat. I'm taking someone else's place on the pontoon and I need to fix it very urgently.
Problem Description: There is no spark on the high voltage wire of the ignition coil.
The crankshaft sensor gives out 150-200 rpm, its contacts look good, I did not change it to a new one. I see 5V power on it.
Camshaft sensor replaced. I see 5V power on it.
The distributor cap and rotor have been replaced.
Coil and ignition module replaced. I see 12V power on the ignition coil and ignition module after turning the plug to ON for a few seconds, after that I see 0V and at the moment I crank the motor I see 12V.
Fuel injectors see 12V, as well as on the coil and module.
I can't check the integrity of the signal wires from the sensor as there is no wiring diagram for my motor.
I did not replace the crankshaft sensor, because the heat exchanger interferes and I see the tachometer readings, I'm not sure if it's necessary.
