VicS
I too have an Oceanranger and the piddle through the small hexagonal hull fitting on the starboard side is, i've always understood, simply a 'tell-tale' giving a visible indication that the seawater cooling system is running fine.
Not just a tell tale but more importantly it is the route by which air will enter to break the syphon when the engine is stopped.
While it's peeing it confirms that the vent is not blocked and should therefore function as intended when the engine is stopped
