boathead
Morning folks, can anyone advise: I have a fella here with an engine problem, the engine is a 1979 Vovo Penta 2003. It is delivering fuel to only the last injector. We've taken the pipework off from the 'pumps' and turned the engine over. Fuel comes out of No.3 pump but not the other two. Cam and pistons o.k., if we slacken pump 1 & 2 by a half turn and turn engine over it shoots fuel out 20 yds. but tighten back to correct setting and nothing. Number 3 (which we assume to be the only one working correctly) doesn't blast the fuel out i.e. we can put a finger over the open end and fuel just pushes out, is that right or should they all blast fuel like a high pressure hose? This is being done with the pipework off the pumps so we can see where fuel is going, and obviously as the fuel inlet side is at No 1 and No. 3 is the one with the return, fuel is getting there via 1 & 2 because No 3 delivers fuel, but is not coming out of 1 & 2 unless we slacken the individual pumps and then as said the fuel 'jets' out 20 yds.....................
We decided to take one of the pumps out but it began to feel tight as we slackened it so stopped. We thought maybe if we took one out we may see what the problem was. We were a bit worried about the shims too if we did take one out?
Anyone got any ideas what this problem might be, or how we can go about diagnosing it?
Cheers.
Cheers.
