dylanwinter
cheers Vic
the only inboard I have ever had was the slug
and the flyweel was on the front
however, the md was a lovely tractor sized flywheel
so can I just decant the diesel into some demi-johns and then siphon the goodlooking stuff back in to the tank via a paper filter in a funnel
bless you vic
good man
D
The flywheel is located between the engine and the gear box . Just like it is in every car engine that I have seen
Diesel bug exits as a thick sludgy layer at the diesel oil/water interface.
Drain off some from the bottom of the tank or extract some from the bottom with a "thief" via the filler ( I think thats possible on a Centaur).
Provided you get a sample from the interface between the oil and any water present you will see the bug if it's there.
If the tank has no water in the bottom it will hopefully be bug free.
Diesel does not deteriorate so unless contaminated can be used, unlike old gasoline which can give problems.
Local council tip may take unwanted diesel with other waste oil otherwise a try your friendly local garage..... or simply burn in your central heating boiler ???
bless you vic
good man
D
