warrenmarkus1
On a long run today, with the engine at about 60% throttle, the engine overheat alarm sounded. Their was water coming out of the exhaust (sea water cooled) and no steam, and the head was hot.
Throttling back the engine, the alarm went out. 30 mins or so later when we increased the engine speed the alarm went off after a short while, again there was water coming out of the exhaust, and no steam. Again throttling back caused the alarm to switch off.
A blockage in the raw water intake, or damaged impeller, or stuck thermostat would cause the would cause the head to get hot enough to vapourise the water giving steam in the exhaust - which has happened in the past when the inlet water strainer got blocked.
But having water in the exhuast, and the engine over heating has me stumped!!
Suspect sender unit perhaps - but how do you check it?
Any ideas gratefully accepted!!
