steveej
Evening All,
Hope 'Lockdown' is not making you all go insane and you are making the best of the situation.
I need to replace the Volvo dripless shaft seal on my Jeanneau SO32. I have managed to separate the shaft coupling but I am having a hell of a job getting the coupling off the shaft.
The shaft is 1 inch and the stern tube is 25mm which is a bit weird.....I can only put it down to the previous owner fitting a kiwi prop and (I believe) changing the prop shaft to imperial. Not the best idea given the seal is either metric or imperial and I have a mixture of both (Imperial shaft and metric stern tube).
Anyway, the nut that holds the coupling onto the shaft is off but I cannot get the coupling off the shaft even with pullers.
I was wondering whether there was some kind of circlip inside the coupling and then I came across this.....
Volvo Penta Exploded view / schematic Shaft Coupling, Locking Pin: 25mm MD2010-C, MD2010-D, MD2020-C, MD2020-D, MD2030-C, MD2030-D, MD2040-C, MD2040-D - MarinePartsEurope.com
which seems to suggest there is a locking pin, but I have not noticed it (and obviously can't go and check given we are in Lockdown.
The pullers are starting to damage the end of the prop shaft.
Anyone taken one of these off before. The Boat is 2003, and the kiwi prop (and shaft) installed a few years later.
Help much appreciated.
Regards
Steve
Regards
Steve
