Ric
Thank you for all the helpful replies so far. I went down to the boat today, and did the following:
1) Checked all the wires around the control panel, particularly to alternator warning light - no obvious fault
2) Disconnected Sterling regulator to eliminate that by disconnecting the white lead
3)Measured volts at engine battery - 13.40 - it is fairly new
4) Measured domestic batteries - 13.6 (they have solar charging)
5) measured volts at alternator and exciter - zero as you would expect
6) Turned on the "ignition" - exciter goes to 3.8v
7) Started engine. No alarm for about 10 secs. Then alarm starts so increased rpm to around 1500 which silenced alarm.
8) Measured volts at alternator - initially about 13.35 - then gradually climbed to 13.40 again - ie the same volts as the engine battery as it recovered after starting load.
9) After about a minute, alternator alarm sounded again. Increased to 1800rpm and this silenced alarm
10) Measured volts at engine battery and alternator - still the same at 13.40.
So any suggestions with this new evidence?
