thesaintlyone
In general I think the idea of electric propulsion has yet to gain much traction because of the limited capacity of currently available batteries. I looked at the Uma site and would note that they have been cruising the ICW, hardly the most demanding environment. They also state that they wait for favourable winds before moving, which is fine with their lifestyle but may not suit the average leisure sailor.
Translate the project to the UK or a transatlantic crossing. Firstly, solar panels simply won't generate their stated output in the prevailing weather in the UK, so charging time to top up the battery becomes longer. Then dealing with tidal currents will sap the available power, as you need to increase thrust to overcome the tide: yes, you can in theory plan your sailing to make best use of tidal flows but you need to be able to cope with the unexpected and running out of battery power before you can reach a safe haven is something you need to bear in mind.
I think that the boat on the Uma site is a great concept but it lacks any redundancy in the system. Loose your ability to generate power and you're in deep,trouble. Not too serious a problem on the ICW but a real problem approaching a Caribbean island where you need power to negotiate the reefs before you can drop anchor because the wind changed from that forecast.
If the op is determined to go down the electric propulsion route, then if it were me, I'd be looking to fit or carry a generator so that at the very least I could produce some power if the solar/wind got put out of action for some reason.
I have also been reading here
www.bwsailing.com/bw/gear/silent-running/
The generator idea does appear to be the way to go and is even used on the Jeanneau 64 in the above article
