Volvo MD1 - ignition warning light
penultimate
12 Sep 2004
Cargreen, Cornwall
The ignition warning light on my Volvo MD1 which forms part of the alternator field circuit has failed. This 14V 2.5W SC screw lamp is not listed in the Lucas catalogue. Any ideas where I may obtain a replacement?
VicS
13 Jul 2002
12 volts will be perfectly Ok. You should be able to get one from a car sares shop, even Halfords The watts will not be critical but get as close as you can as the current flowing through the bulb is the initial field current for the alternator. You will certainly be able to get 2.2watts.
Maplin also have them if your have a handy Maplin shop.
IF you are absolutely determined to get another 14 volt one then you will get them from Alampco
The fitting size will now be described as E10 I think you will find (Thats the old screw in torch bulb size)
