64Kiwi
Hi
Keen for any suggestions or advice on what could be the issue. Twin VP KAMD300s, the port engine starts up fine with no issues (power and light on the EVC panel). When attempting to start the starboard engine it will not crank and there is no light on the EVC panel for the stbd engine before turning the key to the run position (even after switching in the port engine start battery to assist).
At the first position of the key, the alarm beeps as normal and the volt gauge reads 13V which then drops to zero on trying to start the engine so it sounds like an electrical fault. Tried emergency stop and relay reset on top of the engine with no change.
Power also drops out to the Seafire fixed extinguishing system in the engine room (power status gauge on dashboard) when turning the key which may also be the culprit but then surely the port engine wouldn't start if there was a fault with the Seafire system
Brand new start batteries and house batteries but haven't checked the battery volts/condition directly (will take a voltmeter next time I go down). Any ideas?
James
James
