1fast35SC
Hi, I’m new to the forum. Through searches I have seen very knowledgeable responses to questions regarding Volvo EVC faults. I am having troubles and appreciate any help. Thank you.
Boat: 2012 Regal 35 Sports Coupe
Engines: dual Volvo 57GiCE-300-R with stern drives DPS-B1.95
EVC-D
Here is some history of the faults:
10/28/24: Port engine started, but red EVC fault. I shut the engine off and when attempting to restart: “Can Not Start, Gear Engaged” and Port engine hours on the display reads “0.2 Hours”. It should be about 258 hours.
2 faults: 164-253-9 HCU Calibration Memory & 164-232-5 HCU Subnet 1 Control Link.
Cycled batteries on/off and faults went away and engine hours went back to normal. Used boat for about 1 hour.
11/3/24 No faults, normal use of boat for about 2.0 hours (started engines twice)
11/11/24 Turned port key to on position and display did not power up. Turned starboard key to on position and it allowed the port side to power up. Started port engine and got EVC fault port engine, reset battery and fault went away and went on ½ hour ride and anchored.
After anchor, started port engine and get fault (No Steering Port engine). After cycling battery power it allowed steering including joystick, but 3 faults listed:
187-232-2 and 187-232-5 PCU Subnet 1 Control Link, 164-232-5 HCU Subnet Control Link
11/18/24 after unplugging and plugging back in several X2 connectors on the port engine:
4 faults port: 187-232-2 and 187-232-5 PCU Subnet 1 Control Link, 164-232-5 HCU Subnet Control Link, 250-232-5 SAE J1939 Subnet control link
Since then I have performed several Auto Configurations and throttle calibrations. During Auto Calibration the port engine stern drive gauge angle wonders around, but is normal after and when using the boat. And when the engines have sat with battery power to them for any length of time, when the port engine key is turned on, it will not power the display. If the batteries are cycled or if the starboard key is turned on, it will power the port display. The boat can be used and the joystick even works, but I’m getting these faults:
Port - 3 faults: 187-232-5 PCU Subnet 1 Control Link, 164-232-5 HCU Subnet Control Link, 250-232-5 SAE J1939 Subnet control link
EVC-D
