onlyme
Active Member
I have searched the forums and find loads of information on steering rams but I have a different problem.
The port steering ram on my friends Jeanneau Prestige 34 HT (twin D4-260’s) was leaking and has been replaced, the system was fully bled and topped up with ATF in both the orbital unit and the high pressure reservoir.
After a high speed run of around 10 minutes the steering became lumpy and felt just as if the high pressure pump had failed and we were reliant on the manual orbital pump to steer. We slowed down and after another few minutes the orbital unit ran out of oil and steering lost. Running the boat back to the moorings at low speed and the steering returned to normal allowing us to place it back on the moorings safely. I then checked the system and found no oil in the orbital unit but the HP reservoir full to overflowing.
Any suggestions as to what is the cause, my thoughts lead to me think it might be a pilot operated shuttle valve bypassing but without access to a circuit diagram I am not familiar enough with the layout to be certain.
Thanks in advance for your help and look forward the vast knowledge on here helping to pinpoint the issue.
