frothblower
Hi All.
Has anyone else experienced/seen on their VP D4/D6 a small oil leak that at first glance appears to be coming from the right end cover as you look at the manifold that holds the 2 vertical oil filters but on further inspection/removal it is actually where the corner of the manifold has corroded away and the fixing screw on that corner holding the end plate in position is now doing nothing hence the oil now leaking out from past the O-ring in that corner.
Having had a google is appears I am not alone in this corrosion issue in the same place, there is even one for sale on ebay at the moment with the same corrosion issue. (item No. 254203102255) Hoping someone may be able to offer some advise from their past experiences but i'm hoping that this can be repaired maybe by having it welded then drill and re tapped or another solution as the Volvo price for a new manifold is eye watering. Would also like to know what causes this issue so I can try and stop it happening again in the future. Engine is a 2006 260hp with 370 hours.
The VP part number is 3584419.
I will try and post some pictures. These are of the one for sale on ebay but very similar to mine if not a tad worse.
