pistonbroker
Active Member
I did a search and could not find this query before, apologies if this has been covered and I missed it. I upgraded my boat this year to a Bavaria 37 Sport with Volvo D4-300s. I am just getting used to it and am so far very pleased. When I bought the boat I noticed a squeal from the starboard engine and at the time thought that it either need replacing or re-tensioned. Long story short, I have replaced both belts on both engines and have re-tensioned them warm as the Volvo manual advises. I do however still have slippage on the starboard engine which has the power steering pump and an alternator.
On engine tick over there is no slip and when I turn hard to port or starboard when stationary there is no slippage. If I get underway, again no slippage through the rev range or under change of direction. I think I have probably ruled out the steering pump now. However I have noticed that in slow speed manoeuvring when using the bow thruster the starboard engine belt starts slipping. Additionally when I use the windlass when anchoring up I get belt slip. This also seems to coincide with a drop in voltage seen on the helm voltmeter. I need to check but I think the starboard engine must charge the battery for these items.
So the question is has anybody experienced this before? Was it a battery issue, or alternator issue, or both? I am assuming at the moment that its a battery problem and that the alternator cannot keep up with the demand and therefore slips under load.
Any thoughts or assistance most appreciated.
