asteven221
I have posted this before and tried to find it so I could continue rather than go over old ground. Unfortunately I can't find the thread!
So the issue is that the engine performs fine and does not overheat, but emits smoke - or more likely steam.
So far I have done a number of things such as replaced the exhaust elbow, replaced the hoses from the seacock to the water pump and recently changed the volvo
strainer to a vetus strainer. I have what I reckon is plenty water coming through the saildrive leg.
Now that i have a strainer I can see through the lid and hoses that are clear I can observe the water flow and it looks odd to me. Maybe it's normal so I would appreciate anyone's comments on normal or not.
What I noticed is that there is what looks like a solid flow of water from the seacock, but the volume of water in the strainer seems low. The outlet hose from the strainer has a lot of turbulence.
I was expecting the strainer to be pretty full of water.
The engine is doing about 1800rpm during the videos. Temperatures are around 35c on the exhaust elbow, Circa 78c on most of the hot surfaces of the engine with an increase in the sump where it goes to the high 80's if I recall correctly.
I will try and post some video.
Thanks a lot for any assistance as this is a very annoying problem, although not so far stopping me using the boat.
