prv
We ran up the engine the other week to test new fuel system, remote oil filter, etc. All fine, but after a while we noticed that there was barely a dribble left in the coolant header tank. I don't think it's leaking or that there's been any actual overheating of the engine, but obviously the level needs topping up.
I duly bought 5 litres of genuine Volvo coolant from Keypart, from their page specific to the D1-30. Therefore, this coolant ought to be the right stuff for the engine. However, on opening the bottle (actually, on it leaking very slightly in the back of the car :/ ) I find that the new stuff is green and the dregs in the header tank are pink.
Anyone know what's going on here? I assume they can't be mixed, so is the pink OK and I can get some more of it and top up? Or do I need to drain and refill with the green? Obviously there's an argument for draining the system anyway in order to clean the heat exchanger etc, since I don't know when it was last done, but I want to move the header tank at some point in the next few months so it makes sense to leave it until then and only have to drain down once. Only had simple raw-water engines before so not really sure how much effort is involved (do you end up having to bleed calorifiers etc?).
Cheers,
Cheers,
