VicS
The potential problem with this is that the stop solenoid will have power on it continuous and unless the stop solenoid is rated for continuous operation the solenoid would over heat and burn out or worst cause a fire.
Yes you are right which is why in an earlier post I suggested a relay with a timed on period or perhaps utilise the oil pressure alarm sensor to deactivate the stop sequence once the engine has stopped .
