Arthur 1019
New Member
Hi . Any idea how to pair aq 280 outdrive (10 coarse splines )with aq131 4 cyl engine (26 fine splines).
What parts needed, etc...?
Change the jackshaft or the outdrive uj . I’m might have some good used uj from 290 drives , that’s if they fit , I’m not sure without comparing them physically.
Thanks for reply. That's what I was thinking to change u joint but wasn't sure about compatibility. What is "jack drive "? You mean drive shaft in bellhousing unit? Please check what parts you can source for me to get this setup working.
Hi Arthur,
peeps here are v happy to make suggestions and help out with problems, but this is not a site that supplies parts.
have you done this kind of conversion before ?
Oldgit,Need to remember that the engine is going to have to be moved to gain access to both sides of transom assembly especially to remove that internal bearing.
We used a very basic scaffold pole tripod with block and tackle system, if you do not want to go to the expence of cranes and Hi Abs etc.
Do the top hat steering fork shaft seals. while you are in there ,cost pennies.
That jack shaft costs a fortune new, a good secondhand one with correct splines is like rocking horse poo.
However there is lot that can be done to rescue your old one if needs must.
Good luck.
