lewlew100
I have just bought a boat with a Volvo aqd40 engine and 280dp leg. Water has found its way into the bell housing so the bearings to the short drive shaft need replacing. I have been told that this is an engine out job, which will probably be quite difficult for me to achieve. It has been suggested that it may be possible to remove the flywheel cover and bearing housing if the rear of the engine is supported and the transom shield removed to give access through the transom hole. Does anyone have any experience of this please - is it a practical solution? Thanks Geoff.
