Volvo 2003 Engine Mounts
oldsaltoz
4 Jul 2001
Australia, East coast.
Looking at replacing the three engine mounts on both the 2003 with S-120-B Sail drives.
They have two mounts under the engine and another single under the gearbox.
Have been quoted AU$420.00 each for the ones under the engine, still awaiting a figure the gearbox one.
There must be an alternative to extortion. Any advice?
Avagoodweekend......
3 seems an odd (i.e. strange) number. My 2003 (not a saildrive) has 4. In the UK, there are several possible sources; I don't know if they would ship to Australia.
ASAP
Volspec
Keypart
HTH
Derek
My 2003 (not saildrive) had 4 mounts, one of which fractured. I subsequently found that this is a common problem, so Volvo have redesigned them. New design from Volspec cost about £80 for the 4, if I remember correctly. In fact I never used them (Volspec kindly refunded), got fed up with failing engine, and replaced with Volvo MD40 - about the same dimensions but 4 cyl/40 hp. Vastly improved performance
Looking at the price ranges above it would seem the Cairns VP dealer is enjoying the fact that no other VP dealers are close enough to be a problem.
I would love to prove him wrong. So will continue to search for an alternative, please post if you have any more information.
just done all 4 on a shaft 2003. cost was 77.94 for each mount and (believe it or not) 50.96 for the mount bracket that had sheared, a common fault. volvo mounts unlike yanmar , are just the rubber bit and you even have to re-use the bolts.
I did initially try to change just the delaminated one leaving the other three in situ, but I was getting problems with the remaining three having softened up and the engine was vibrating badly. doing all 4 magically changed this.
unfortunately (or deliberately) the design of the front mounts meant I could not find any cheaper pattern ones.
volvo have changed the mounts on this engine so often that I got three different answers as to which were the correct ones - from Volvo themselves!
if you want to post the part numbers I will get you the uk price, but tbh in rip off Britain its not likely to be much cheaper than Oz
