jmuir1
Hi,
where do i install an anti-syphon loop/valve on this engine?
cheers
john
cheers
john
Hi,
Its a freshwater cooled engine but unsure if i can install it on the sea water outlet of the heat exchanger as it looks as this goes straight into the exhaust elbow from volvo 2002 manual. I can install it between the seawater pump and the heat exchanger as it looks like the pipe on the heat exchanger is held in place with a small metal plate. Is the hard pipe from the seawater pump just a push in fit?
John
ps thanks for input so far...always grateful for info!
