VOLVO 2001 lack of power
alf1
2 May 2006
holmfirth
with no load the engine will rev to 3200.On load it will only go to 2400.air filter ok new fuel filter fitted.new block 5 years ago with new piston etc.No smoke from exhaust.slow to pick up revs.Any suggestions please.
ParaHandy
18 Nov 2001
and is there still no smoke if the throttle's wide open? Are you doing this "test" whilst tied up? If you are then that's about right.
wotayottie
1 Jul 2007
swansea
Unlikely to be prop problems since your engine isnt smoking. More likely to be lack of fuel ie partially blocked filter. Either way check out the obvious things like fuel supply, air filter etc.
If none of them have an effect, then check valve clearances and compression .
lezgar
15 Aug 2001
I have the same problem in a volvo 2001. After cleaning the propeller power increased but not like before. If you find the solution please tell to me.
Bilgediver
6 Jun 2001
Scotland
Sounds about right....:) What did you expect. The poor engine is blasting leccy into a discharged battery, turning a dirty propeller and you may even have the boat tied up. Give it half a chance.
alf1
2 May 2006
holmfirth
I have done the test both tied up and moving. Boat was put back in the water in march with a clean bottom.Lost nearly 2 knts.
