superheat6k
My Cummins 6BT5.9M engines have a Lucas CAV DPA distributor type injection pump. This incorporates a 12 volt stop solenoid. Energise to open / run, de-energise to stop.
Recently the engine simply stopped shortly after starting which led to me mis diagnosing a faulty injection pump most due to the load click / snap sound that emanated from the pump as it stopped. Anyway the pump has been fully inspected and re-tested and all is fine, and its calibration has been adjusted, but shortly after the pump was reinstalled and after initial re-start, the following day the original problem recurred. So I measured the voltage at the solenoid connection. From 13 volts pre start the voltage dropped to ~ 7.5 - 8 volts when the engine was refusing to start.
However, the engine was spinning freely on the starter, and this is a big 5.9 litre 6 cylinder engine. The battery is 125 AH.
I had found the engine battery isolator switch was not working so I replaced this, and all the connections on the start circuit are good.
My suspicions now are that the crank battery is simply losing too much voltage at start up, but it spins the engine with ease.
What is the minimum the terminal voltage should fall to during the start up ?
BTW I did run a separate feed direct from the port engine and this allowed the engine to start without a problem.
I was intending to run a series of voltage drop checks, but after the first check of the stop solenoid the voltmeter decided to go for a swim in the oily bilge water I was about to clean up from the works I had just concluded and is still drying out ! I will be checking the battery charge status with an hydrometer, but fear it is new battery time.
Or should I change the stop solenoid first ? This works fine at 12 volts, but doesn't not sty open at 8 volts.
