Voltage Sensitive Relay
DaveS
25 Aug 2004
West Coast of Scotland
Voltage Sensitive Relays (VSRs) do not seem to be widely known about, yet they would seem to be a much cheaper alternative to more complex arrangements for keeping domestic and cranking batteries seperate while discharging but correctly charged by a common alternator.
Until this weekend the main DC supply arrangements on my boat were fairly straightforward. One 105Ah "leisure" battery rated for starting and one 110Ah deep cycle battery were each connected via an isolator to a common point which supplied the starter and the distribution board. The 14V 50A machine sensed alternator was also connected to the same common point.
Before starting the engine I would switch on the "start" isolator then switch off the "domestic" isolator. After the engine had run for a few minutes I would switch on "start" and switch off "domestic". This worked well enough and I never actually endangered the alternator by switching off before switching on, but it was something else to worry about. I thought about replacing the isolators with a make-before-break "1,2, both" switch but never got round to it.
What finally prompted me to modernise the electrics was the purchase last year of a Navman 5500 plotter. It's a really great bit of kit, but it does have one annoying "feature": if it sees a supply voltage dip (e.g. when starting the engine) it shuts down. On re-starting, the current route is no longer active. You have to start the route then skip each waypoint in turn until you get to your current leg - and if you overshoot you have to start from the beginning since you can't go back! This is a real pain in the proverbials.
I spent some time thinking about wiring options. Separating the domestic and cranking functions was clearly essential and it would be nice to eliminate manual switching, but then there is the issue of charging both batteries from the alternator. Blocking diodes of course - but the voltage drop would seriously reduce the charge rate. So get into the alternator to try to convert it to remote sensing? Fit a smart charger - and still probably need to get into the alternator? As an alternative approach I thought about a split charge relay driven from the field winding, and then came across VSRs.
One of these is now connected between my battery isolators and the other commoning connections removed. The distribution board is now connected only to the domestic battery, so does not see starting voltage dips. The starter and alternator are connected to the cranking battery. On starting the engine the cranking battery is charged by the alternator: once it reaches 13.7 volts (a few seconds or more depending on how long the engine took to start) the VSR closes, paralleling the batteries which are then charged together. When the engine is stopped the voltage falls: when it reaches 12.8 volts the VSR opens leaving the cranking battery fully charged. Simple!
So both isolators are now left on throughout a cruise. Back at the pontoon, where a smart battery charger keeps all batteries topped up, there is another benefit. With the cranking battery isolator opened the cockpit engine controls are disabled which was not the case before. (The domestic isolator is left on to keep the fridge going and the Navtex receiving.)
We'll see how long it lasts: I hope indefinately, but with anything electronic there's always doubt. I have kept the old cable links so that the system can be readily put back to manual operation.
I bought my VSR from Merlin (usual disclaimer). Its a New Zealand make (can't remember the name - three initials, something like BMR?) It's 100A rated and cost £50 but it's in a nice box with a LED which lights to show when the relay is closed. I've also seen pictures of French made units of lower current rating which are probably cheaper and look like car relays.
A
Anonymous
Sounds all very sensible - the company you are thinking of is BEP and they make fairly good kit. Personally I wouldn't have done all that only for the Navman (you like to support NZ, eh? /forums/images/graemlins/smile.gif) - consider feeding essential electronics such as GPS, plotter, etc., from a very small separate battery, maybe a small gel battery, to provide essential services even if the main power fails. Mind you, I haven't got around to doing that myself, it is on my 'wish list'! Nevertheless, you have a much improved charging system, for sure.
jfm
Jersey/Antibes
This is very good stuff, very sensible imho. The BEP stuff is good kit. We just got a generator/inverter auto swithover device from them for my brother's boat and it's excellent. I saw your VSR gear in their catalog
anabel
14 Feb 2003
Shannon Estuary, S. Ireland
Agree with you. Winter before last was in NZ & saw the system you mention in a chandlery & purchased same. Fitted it when I came back & found it a very useful piece of equipment. Previously had the 'On-I-Both-2-Off' type switch which I found to be a bit of a pain as I was forever forgetting to use it properly. Now as soon as I go on board I just switch on 'Start' & 'House' switches and forget about it till I'm leaving the boat some days later. The model I got was the "BEP 716SQ" If needs be there is the facility of switching the batteries in parallel. All together, an excellent piece of equipment. tho' not cheap. You get what you pay for!!
Rgds.
Anabel.
bdsweeting
28 Feb 2004
Fitted a VSR from Merlin, along with a set of switches to my last boat (broke the knob off the old one two weeks before I sold it !!) and it seemed to work fine.
My current boat is just a small fisher with two 80Ah batteries and a machine sensed alternator.
Charging connection is presently through a small relay controlled through the ignition/starter switch. This is cheap and simple but I am planning to change it to a more 'automatic' control by switching the relay on via the oil pressure switch.
This means that the abtteries won't be connected to each other until the engine is charging.
William_H
28 Jul 2003
West Australia
I think VSR would be the way to go. if any one is interested I can give some description of how to build one for anyone with a little electronics will and a soldering iron. In this case you can choose a relay to suit your need or budget. PM me if anyyone is interested. However a relay can also operate from things like an oil pressure switch or from the output of the aux (tacho) terminal on the alternator. This means batteries are paralelled not when voltage rises but rather whenj engine is running. That is nearly but not quite the same thing or as good.
Now for any one with trouble with electronics dropping out when starter pulls battery voltage down instead of a separate battery you could feed the electronics through a silicon diode of enough amps rating. You then connect an electrolytic capacitor of more than 12 volt rating from the electronic device input to ground. The capacitor acts like a low capacity battery ( without the cost or need for care) feeding your plotter etc. while voltage is low. The diode stops the capacitor trying to feed the starter. electrolytic capacitors are rated in microfarrads. They always have a positive and negative terminal. I would suggest you ask for one minimum 5000 ufd but more would be better from usual electronic supply sources. you can add capacitors in paralell to increase the capacitance. you should have a cylinder perhaps 4 inches long by 1.5 wide. Don't be confused as capacitors come in 5000 nanofarrad or even picofarrads also. The more capacitance the longer it can supply voltage support while engine is cranking however once an engine starts cranking the voltage usually recovers somewhat because starter current reduces with cranking speed.
I can't guarantee this fix will work in practice but for small cost it is worth trying and it will protect your plotter or whatever from interference of some sorts and voltage spikes. regards olewill
cpedw
1 Jun 2001
Oban
Isn't this the same as a Battery Combiner that West Marine sell?
I've not tried this as my boat came with an Adverc charging system but it would seem like a simpler alternative. It wouldn't get the high charging that Adverc achieves I suppose but it avoids interfering with the alternator.
Derek
DaveS
25 Aug 2004
I did think of a small gel battery (or even a large capacitor) for the electronics - fed via a diode from the domestic battery - and that was the back-up plan if the VSR didn't fix the problem. But it did!
DaveS
25 Aug 2004
More or less, but the West unit is a good bit dearer. The website description also quotes a single operating voltage of 13.3V whereas the BEP unit has significant hysteresis between its switch on and switch off voltages: these appear to have been set at just below "charging and full" voltage, and just above "fully charged and resting" voltage, respectively. 13.3V is a bit of a compromise, neither one thing nor the other. I would also guess that if it really has little or no hysteresis designed in, then relay chattering would be quite likely if the domestic battery was low.
DaveS
25 Aug 2004
I did consider making up a unit from scratch: a dual comparator, logic gates, driver circuit and relay: probably under £20 from RS for the lot. And then I thought about how long it would take to work out the board layout, build the thing, find a box to put it in etc. and thought "forget it". Instead I spent £30 more and now have a quite attractive commercial unit operating on the boat instead of a part-completed project lying about the house!
Don't get me wrong - I'm more than happy to go the DIY route where the ratio of cost avoided against time spent is higher. For example, having seen how much a commercial bi-directional anchor windlass control unit was, I made up my own - which also includes a "slow-motion" option that I haven't seen on the commercial units - for less than a quarter of the cost, taking (from memory) about 3 hours.
I did think of a split charge relay driven either from the field winding or the oil pressure, and I would have probably gone that route if I hadn't found the VSR. In my opinion the VSR is better, in that it directly measures the relevant quantity, i.e. crank battery voltage, rather than something else which is only loosely related to it. With a nearly full crank battery there's probably little to choose, but if things were not going well and, after starting, the crank battery was low for whatever reason, I'd prefer to have it fully replenished before paralleling the domestic.
adelaidem
1 Mar 2005
Hi, I am planning on ordering the “bep716h90avsr" battery cluster package, my questions are
1) It states batteries up to 90ah for this model (i am planning on fitting 2 x AGM batteries and 1 x acid lead cold cranking battery) the AGMs are 100amp hours each so will the system cope with this battery configuration????
2) I take the VSR will sense the different voltages between the acid and the AGM, I have read in late u should not mix the batteries but I think your system will overcome this is this correct????
3) Do I have to bank my 2 x AGM batteries together or does the bep"716h90avsr” have 3 x on/off switches????
Hope you can help with these questions
Will be much appreciated
Regards matt
pvb
UK East Coast
BEP 716-H-90AVSR...
Matt, the 716-H-90AVSR is a "battery management cluster", which comprises 3 on/off switches and a VSR. One switch isolates the start battery; one switch isolates the house battery/batteries; one switch is an emergency parallel to link the start and house batteries together if needed. The VSR connects the charge to the house bank as soon as the start battery has reached 13.7V, and disconnects the house bank when the voltage drops below 12.7V (when the engine is switched off).
As to your questions. First, the 716-H-90AVSR will handle charging currents up to 90A (ie alternators up to 90A), not "batteries up to 90Ah". I assume your alternator isn't bigger than 90A. However, there is a limit to how much house battery capacity you can have with a VSR, but your 2 x 100Ah AGMs will be just within the limit, so it will cope OK.
Second, the VSR only senses the voltage at the start battery. If you have a standard alternator, there'll be no problem having a mix of ordinary and AGM batteries.
Third, the 716-H-90AVSR only has one "house" on/off switch, so you will need to connect your 2 AGM batteries in parallel as one bank. This is also the most efficient way to use these batteries.
Hope this helps.
