forrestmichael
Active Member
Me again... i've currently got a very simple one battery does all setup, i want to add an additional battery for equipment only leaving one for engine only and an isolator switch to choose which is charged and which is used etc. I can understand all that bit and unless i'm wrong don't need anything more.
I really want to limit engine running time for charging however, i've read that a charge regulator which feeds the battery more efficiently can greatly reduce charge times. If I wanted to later add a solar panel could I connect this into this charge regulator also.
And finally, can anyone recommend a charge regulator for this purpose.
Thanks as always
Michael
Thanks as always
Michael
