halcyon
My Lifeline AGM manual says 0.5% of capacity at 14.3v.
The problem is you can't set up an Ah meter to this value because the charger will have dropped down to a float voltage long before the current reaches 0.5% of capacity at 14.4 volts. That is why this has to be manually controlled if you really want to check when your batteries are back to 100%. Let them stay at a float voltage for another 12 hours to get fully charged, but don't say your solar panels have fully charged your batteries by lunchtime because you controller has dropped down to float mode!
When my SmartGauge tels me, or when they've been on shorepower for 24 hours which I do once every 2-3 weeks.
12 hours @14.4 volt will not improve capacity unless the previous charge up to 14.4 was bad, with a correctly charged battery charge current will fall to milliamps.
How does your smartgauge know the battery is at 100% capacity ?
Brian
