ghostlymoron
I'm not convinced of the value of a battery monitor. Long term they are just too inaccurate and IMO wrong information is worse than no information.
I've got one of these
http://www.smartgauge.co.uk/smartgauge.html
Don't understand how it works, but it seems more sophisticated in its operation than NASA, but at a price.
I know exactly what he means. If not all the load AND charging sources are connected via the shunt then the Ah count will be wrong. It might have been installed correctly, but later someone has come along and installed something else and not realised there was a battery monitor and a shunt!!!!!Mmm... I wonder what he means by "incorrectly".....
Peukert's equation gives you a very precise understanding of what you batteries will deliver under different current discharges. Read about it and then adjust your OPINION afterwards."Peukert's equation" - the expression NASA uses - bestows spurious credibility on what is, in my opinion, essentially a rule of thumb........
It's a great shame that the cheapo Nasa doesn't allow you to programme two of these essential parameters!
But they are a useful source of both voltage and current in/out. So easy to see how well your solar./wind are doing when the fridge is running etc. And maybe more importantly, can give a good indication of when the batts are close to fully charged, if voltage is in the low fourteens and just few amps going in then it's looking good. Mine resets to 100% with definable volt/amp settings so if you are being nice to your up batteries and getting them fully charged every day should never drift too far.I'm not convinced of the value of a battery monitor. Long term they are just too inaccurate and IMO wrong information is worse than no information.
Try a bit harder - you could surely manage a bit more patronising. I'm sure you're right about everything your say. I'm aware of how little I know, and was largely plagiarising on the views of a battery researcher I know. Comfortably confident that I understand my ignorance, I have spent long enough in scientific research to gain self-awareness in that regard. All of your message when though my shunt - which caused it to heat up enough to affect the precision of my response.I know exactly what he means. If not all the load AND charging sources are connected via the shunt then the Ah count will be wrong. It might have been installed correctly, but later someone has come along and installed something else and not realised there was a battery monitor and a shunt!!!!!
There are three battery parameters that must be input correctly into a good battery monitor. It's a great shame that the cheapo Nasa doesn't allow you to programme two of these essential parameters!
Peukert’s law says that the apparent Ah size of a bank changes depending on the current draw.
A bank is designed to deliver a capacity with a current discharge that will flatten the battery in 20 hours. (The 20 hour rate)
So with a 100Ah battery, a 5A load will flatten the battery to 10.5v in 20 hours.
When drawing currents higher than 5 amps the "actual" bank size will be much smaller, so the bank will not last as long before it needs re-charging. Conversely when using much less than 5 amps the bank size will be larger and will deliver more Ah.
If a 100 Ah that battery has a Peukert value of 1.25, then higher or lower loads than 5 amps will change the actual capacity of the battery by the following amounts.
With a 10A load for 20 hours there are only 84Ah's in the bank.
With a 1A load for 20 hours there are 150Ah's in the bank.
Gosh. Which particular one caused you to form that opinion? Even my cheapo NASA's calibrate pretty accurately against more sophisticated equipment - I check them all the time with almost any meters I can get my hands on. I wouldn't be without them. I used to check the batteries directly with digital multimeters before I had the monitors. Even if the monitors are pretty inaccurate, which is not what I measure, the ability to check at a glance that nothing really silly is happening is very reassuring. I am well aware of the budget-limited frailties of my setup, but despite my obsessive double checking on it, it hasn't ever seemed to seriously mislead. I don't depend on the % charge reading, but the monitors are worth it to me just for voltage and current. That doesn't mean that I know the % charge to be wrong, but since I avoid the bottom half, I'll probably never know.I'm not convinced of the value of a battery monitor. Long term they are just too inaccurate and IMO wrong information is worse than no information.
You are referring to the SmartGauge which I bought when my even more expensive BEP Battery Monitor became very inaccurate. This happens as the batteries age and all the parameters that were entered when installed have changed.I've found the NASAs resonably accurate over a few years and better than some more expensive ones which don't even display current being drawn or input - in my miind one of the most useful functions of the NASA.
Eh? The shunt has got b ugg er all to do with reading the voltage. So the fact that a monitor is "shunt based" does not stop it doing the calculation based on voltage as you say, and that's what NASA say their monitor is doing. I guess they must be lying. The NASA monitor ALSO integrates amps in and out in order to learn the battery parameters by comparing it with the Peukert calculation. At least that's what they say, but I guess they could be lying about that too. The integrative calculation can wander a bit from reality (they say). If the monitor is switched off, restarted, and then left under a light load for a few hours the instrument will recalibrate itself - they claim.You are referring to the SmartGauge which I bought when my even more expensive BEP Battery Monitor became very inaccurate. This happens as the batteries age and all the parameters that were entered when installed have changed.
ghostlymoron was right about the longterm accuracy - but they do have an accurate Voltage and hopefully Current reading which are very useful.
With all these inaccuracy problems the military finally demanded more accurate battery monitors - so enter the SmartGuage.
This is a very sophisticated monitor that uses clever mathematical algorithms to work out the % depth of discharge of the batteries just by measuring the voltage, and it does this over one thousand times a second. It learns the battery status and becomes more accurate the more it "learns", whereas a shunt based Battery Monitor becomes more and more inaccurate over time. Yes the SmartGauge doesn't have Ah readings, but these current meters are fairly cheap and should be installed with a SmartGauge.
Because it doesn’t use a shunt, it is cheaper than most Battery Monitors and is very much easier to install as only two wires need to be connected. The only information it needs is the type of battery being monitored. It does have a huge range of alarms and a very long and detailed user manual for those who want to get the most out of it. A second battery can also be connected to monitor battery voltage only. It has been proved by Enersys, who make Optima batteries, to be much more accurate than a shunt based Battery Monitor.
Yes I have done that dozens of times with different meters under different loads. It has never given a different result to the battery monitor. Why should it? The voltmeter contains a shunt - that's how they work - and the test leads are equivalent to the leads from the monitor. The monitor is (among other things) a built-in volt and ammeter, and I cannot understand why anyone would expect it's being built in to make any difference to the reading. This is not university physics, it's not even A level physics. The voltage and current readings from my cheap monitor are perfectly good, and the ability to glance at it at any moment means you can see instantly what effect it has when, say, someone charges their iPad. The percentage capacity left indicated on a monitor can only ever be an estimate except for ones with a built in time-machine. How much you get out will depend on the load and also quite heavily on temperature.Best method is a voltmeter and ammeter plus the human brain, will allow most people to maintain batteries at a except able level to give a good battery life.
Brian
Eh? I'm not quite sure what points your are trying to make in your last post!Eh? The shunt has got b ugg er all to do with reading the voltage. .....
+1....Best method is a voltmeter and ammeter plus the human brain, will allow most people to maintain batteries at a except able level to give a good battery life....
Another very confusing post - voltmeters don't need a shunt to measure voltage! Two wires connected to the battery is all that is needed - not even A level practical physics - anyone can do it which is the big advantage of a SmartGauge Battery Monitor..... The voltmeter contains a shunt - that's how they work - and the test leads are equivalent to the leads from the monitor. The monitor is (among other things) a built-in volt and ammeter, and I cannot understand why anyone would expect it's being built in to make any difference to the reading. This is not university physics, it's not even A level physics......
You're right. You probably know more than me.Eh? I'm not quite sure what points your are trying to make in your last post!
For clarity to others who might also be confused...
It's the drink, I swear. Did I really type that? I do know that ammeters need a shunt, not volt meters. Apologies. I'll go and lie down. Actually we agree about one thing. It's no problem measuring voltage and current, and capacity is hard. And I accept that some systems for measuring capacity are better than others (but none are great). And this time I will leave off.Another very confusing post - voltmeters don't need a shunt to measure voltage! Two wires connected to the battery is all that is needed - not even A level practical physics - anyone can do it which is the big advantage of a SmartGauge Battery Monitor.
Digital Battery monitor meters are very accurate at reading Volts and Amps - they are just not very accurate at counting Ahs for all the reasons discussed in this thread.
+1Whilst the Smartgauge may be a bit better than the NASA as far as determining capacity remaining, it's useless if you want to analyse what's going on i.e. what's flattening the batteries so quickly? With no ammeter, you've no idea how much charge is going in or what current the various loads are taking out.
Isn't the generally accepted ballpark 1 or 2% of capacity at 14.4v? So a battery SOC meter is wrong if you set it up wrong. Hardly the fault of the meter.There's another "Charging Gotcha" with these "auto-resync" features that makes them useless if you have solar panels. Under cloudy conditions or shade the solar panels may be putting out only 13.6 volts at 2 amps for 10 minutes, so even if the batteries are 75% charged the Battery Monitor will reset to 100%. It is best to disable this feature by simply setting the re-sync voltage to 16+ volts which it will never reach. Re-Sync to 100% when you know the batteries are 100% charged.
My Lifeline AGM manual says 0.5% of capacity at 14.3v.Isn't the generally accepted ballpark 1 or 2% of capacity at 14.4v? So a battery SOC meter is wrong if you set it up wrong. Hardly the fault of the meter.
When my SmartGauge tels me, or when they've been on shorepower for 24 hours which I do once every 2-3 weeks.How do you know when your batteries are 100%? Temp adjusted SG measurement?
