JMax
New Member
Hi all,
We have a Vitrifrigo Fridge (model C180-IXP4-DSV) which keeps fluctuating between the (set temperature of 3 degrees) and 5 degrees C. It does this about every 2 minutes. It will cycle on to get to 3 degrees. Cycle off when that temp is achieved, and then it creeps back up to 5 degrees in about two minutes. My research is pointing to either an aging Thermostat or the Thermistor.
Does anybody have experience with this issue, or any advice re: what direction to look at first (Thermostat or Thermistor)? It one the fridges that has the digital temperature read out.
As an aside if I increase the set temp to 4 degrees then it will fluctuate between 4 and 6 in case this provides any clues.
Thanks in advance.
Thanks in advance.
