fisherman
Arun class lifeboats soaked up water, enough to slow them down. Not osmosis though.
https://en.wikipedia.org/wiki/Arun-class_lifeboat
That Wiki reference says "....The GRP hulls were moulded in blue material in the outer skin. After a while it was found that water was accumulating in the fibreglass which added up to two tons to the weight...."
Unless they were foam or balsa cored and the cores were compromised and sodden that figure absolutely must be wrong. GRP simply cannot absorb more than maybe 4% at worst water, usually much much less. Absorbing 2 tons of water at 4% would mean a hull (just hull, not engines, tankage, superstructure fittings etc) of 100 tons on a 51 ft planing boat.
If it says Wiki don't take it as gospel.
....... a surveyor that looked at my boat a year ago apparently accused it of all sorts of non existent nonsense.........
This is worth a look.....................bit dated now but still very relevant.
Goes into some depth about the hows/wheres/ whys about osmosis.
https://www.yachtsurvey.com/
and more specifically https://www.yachtsurvey.com/BuyingBlisterBoat.htm
I remember at the time they were withdrawn for drying because they lost so much speed, or so we heard. Is that 4% gospel? 4% by weight or volume? Certainly my FV hull was completely soaked and reckoned to be several tons overweight at 12.5 for a 32 footer.
I am not a fan of total gelstrips: you are replacing a chemically integral part of the hull with a "glued on" replacement. I have seen too many "osmosis treatments" fail.
Hi all
Thanks for your replies. We viewed the boat and made an offer which has been accepted subject to survey etc. From the previous survey if it hasn't got much worse we can live with it and get it done later.
Thanks again
David
I have a survey on my boat from 1989, it says the toilet bowl is showing early signs of osmosis. As it is ceramic I am not going to act with too much haste.
My survey talked about a 3 cylinder VP 2030! In fact it is a 4 cylinder uVP MD22
I sold a boat in spite of a survey saying that the VHF aerial was not tested. Not surprising since there wasn't one.
BTW, congratulations to David on the new boat. If you want a new name, try 'Reckless of Deben'.
David there are a couple of Facebook Gib'Sea groups, not greatly active but we help each other out with bits and bobs.Forgot to mention, the boat is Gib'Sea 372, I'll put up some pics once the survey is done and we've got keys![]()
