Bobc
I'll have to get her on board and then fake and engine failure so I can send her head first into the engine bay while I film it from behind
Can I hold the camera pleaseI'll have to get her on board and then fake and engine failure so I can send her head first into the engine bay while I film it from behind![]()
I'm perhaps just old and cynical, but I assumed that the whole thing was staged. Set up cameras, knock out a cap shroud clevis pin, film legs, profit.I'm impressed by their quick reactions. . .
. . . in getting the cameras set up to film themselves dealing with the problem.![]()
Your cynicism knows no bounds. I bet you think all those heroic animal rescue vids on Faceache are staged too!I'm perhaps just old and cynical, but I assumed that the whole thing was staged. Set up cameras, knock out a cap shroud clevis pin, film legs, profit.
She's got mine ?If you slip her a few quid i'm sure you won't even need to fake the engine failure. She was obviously prepared to pull her shorts to one side in front of the old fella in the engine video, for a few more subscriptions.
She's got mine ?
It's not waterproofed, which wasn't an issue even though there was a big sea running. The rig in the water seemed to act a bit like a sea anchor and we weren't getting much spray over the deck.And how did you waterproof it?
I can dreamPerhaps she pulled her shorts to one side just for you![]()
There's a pair on ebay ending in an hour... FELCO C16 TWO HANDED STEEL WIRE ROPE CABLE CUTTER MADE IN SWITZERLAND | eBay
Do you not check the chainplates?Considering that the failure was due to a chainplate snapping, apparently just below the surface, I don't imagine it matters. It's not like rigging checks ever scratch the surface, so to speak.
The boat is a Tayana 37 and such failures are not unknown. Poor design and common with other boats of the same era with the plate going through the deck then to a ply pad which is glassed into the hull. You can see in the shot of where the chain plate was the sealant had failed and result is crevice corrosion where the plate passes through the GRP deck. Almost impossible to check. A Tayana starring in yet another Youtube (forget the name, but they originally sailed from UK in a Heavenly Twins cat) had a failure of the same plate but it pulled the whole plate and pad out through the deck. converted to external plates through bolted to the hull sides.Do you not check the chainplates?
This is a phenomon I have studied extensively (having an eye for detail, I would have gone for 0:32) but it's largely just a Youtube algorithm thing. I've lot count of how many video where I've searched for something utterly tedious & quite technical, only for it to feature the only single frame with a cleavage in. It's deeply frustrating.I looked at the channel and noticed most of the recent thumbnails have her revealing herself but that only started after the one that looks like she's snorkling naked got half a million views. I guess she then realised what sells ...
