Richard10002
I am about to buy a Victron Phoenix Smart Inverter 12V 2000VA
https://www.onboardenergydirect.co.uk/cgi-bin/sh000001.pl?WD=inverter smart&PN=Victron-Phoenix-Inverter-Smart-12V-2000VA.html#SID=36
https://www.victronenergy.com/upload/documents/Datasheet-Phoenix-Inverter-Smart-1600VA-5000VA-EN.pdf
These VA designations always seem a bit dubious/meaningless to me. The inverter datasheet above says that, at 25C it is good for 1600W continuous, with a peak power of 4000W.
I'm merely looking for some reassurance that it will run the Bosch Rotrak 340ER Lawnmower that I use to keep my mooring tidy, (in keeping with club rules). The mower tag says that it is 240V 1300W. I also have a Dyson DC50, which says it's 850W so, if the lawnmower is OK, I'm sure the Dyson will be OK. They both work fine with my existing Sterling 2500W Pro Combi S Inverter Charger*
So it looks like it will work OK, even if the mower were to have a high'ish start up current - but I am no expert on these things.
*The reason I am changing is because the Sterling has a 4A acquiescent current, which means I cant leave it on 24/7, and I occasionally forget to switch it off, which is annoying. In addition, a Victron inverter will work better with the system I have for protecting my Lithium battery bank, and an added bonus will be that the area will be less cluttered.
