prv
He doesn't need AIS to know that you are under sail.
Presumably he does if he's making avoidance decisions at ten miles out, though? Or is that within range of decent binos from a high-up bridge?
On the back of this thread I've just been looking into AIS transmitters (currently have receive-only, and wouldn't want to be without it in the Channel), and it seems like all of the Class B ones have to be initially programmed with a PC and then the values are static. So we can't properly indicate whether we're under sail or not - I assume some people pick "Sailing Vessel" from the list and are then "lying" when under motor, and others pick some variety of motor vessel and are then not sure whether to behave as one for consistency, or whether the OOW has seen their sails and is treating them as such.
Really we need the AIS manufacturers to give us a switch - preferably a pair of terminals to which we can wire our own - with which we can instantly select between the two states.
(If Digital Yacht or someone are reading this, what I'd *really* like is a common terminal and three others, so I can wire up a rotary switch and choose between "Transmit Off", "Motor", "Sail", and "Anchored"
