Inselaffe
Hello
I've just fitted my new Navman 7100 DCS VHF, and not altogether surprisingly to me, it dont work!
I can't pick up anything. I have a new Gomex antenna about which I'm a bit confused.
How do you test if you've connected an antenna properly, or if the antenna is ok?
Should there be a circuit between the outer and inner connectors at the set end of the cable, but only through the antenna - in other words, no connectivity if I remove the antenna?
What I mean is, how does the outer shielding cable connect - is there a connection through the antenna (but only through the antenna) between inner wire and shielding outer wire?
I'm confused because initialy someone told me there should be no connection at all between outer and inner wires. After fitting and making multimeter measurements there was a connection, so I removed the antenna and there was a circuit between the two connections on the antenna itself so I thought new antenna was Kaput. Got another one and it was the same, so presumed my advisor was wrong, now the set dont work, I am not so sure.
I also have worries about the antenna, as I bought it in Portugal, and on the plane home I had to put it in as bagage at last moment with no packaging, as the idiots at secu-tity said I could use it as a weapon, and couldn't bring it on as hand luggage - palhaços! I mean where will it stop, the little old lady in front of me could have used her handbag strap as a garrote. So maybe it got a bash by those gentle baggage handlers.
Sorry If i have rambled on, I am a bit unsettled at the thought that if we lose today my Tuetonic wife, amongst many others here in Germany, will make my life hell /forums/images/graemlins/smile.gif
