D
Deleted member 36384
Guest
Hello,
I have just replaced the mast end of my VHF cable. The Pl239 plug was soldered onto the mast coaxial cable with the copper centre wire soldered onto the PL239 pin and the braided shield bent back over the external flex and PL239 screwed over it. The copper centre insulation was left in place and measured so that the insulation would be just be inside top 1/4 of the centre pin. The soldering was performed with the pin down to stop any solder running back and bridging the pin to the PL239 outer housing and thus connecting pin and coaxial together.
I tested this connection with a multiple meter, tested the multimeter which showed 1 when leads are not touching and 0 when leads are touching. With the red on the Pl239 pin and the black on the PL239 body, I got 0; so good to go. The old cable was pulled and the new cable was run from the mast head and connected to the antenna (a Metze Manta about 5 years old).
I did the continuity test again at the deck end of the cable (no connector just on the centre and shield) and found that it was 0, a circuit. It was late by this time last night so I came home. I have a new Metze Manta Antenna at home as a spare and today tested the continuity on the antenna's SO239 connector between the pin receptor and outside body that the PL239 screws onto at it measured 0 resistance, a circuit.
Having searched the forum, I am now understand that when the VHF cable is disconnected from antenna there should be no circuit between the pin and the shield, when the VHF antenna is connected to the cable, there is a circuit between the centre wire connected to the pin and the shield. The reason for this is due to the antenna construction. Hence, my tests show all is okay.
The reason I am asking is that I get someone to do this for me, but with lockdown everything is taking an age so I did this myself. Just looking for validation that my tests are correct. The reason for the validation is that everyone starts arguing on the threads about nuances and while one or two forumites are clear, the rest muddy the waters, no criticism intended, it's just the way it is.
Is this what you would expect with a Pl239 and SO239 when conducting these tests as described?
As always, thanks in advance,
BlowingOldBoots
BlowingOldBoots
