vhf aeriel - will it work with a tv?
Burnham_Bob
29 Jul 2001
Burnham on Crouch
The mail order chandlers sell splitters that will run an FM radio as well as the vhf. Anyone tried it with a tv? I have a small portable which has a built in aeriel, but needs an extetrnal one where I live. Hoisting a small self contained tv aerial up the mast is a pain. I know vhf and uhf are different, but the set's built in aerial is just an extendable one like a portable radio and I know it works in areas of good reception. Obviously if it does work, I can get a splitter at Maplins for a fractiob of the cost of the Mail order. Just wanted to kinow if anyone had tried it.
Talbot
23 Aug 2003
Brighton, UK
why dont you just plug the normal vhf aerial into the tv it probably has a standard co-ax connector (mine does), then you can tell us all if it works! - unlikely unless you also add a tv signal amp into the circuit.
alan
7 Jun 2001
Nettuno, Italy
As UHF and VHF are separated by quite a 'large' frequency, the VHF antenna will not provide as much as gain at UHF. However, as the tuning is likely done by the length of the antenna and the addition of a coil, and probably does not contain any filters or tuned amplifiers then it will possible give you some gain. Why not give it a go, I suspect it will work somewhat.
However, be careful about fitting a splitter and transmitting on the VHF, half the power (or so) will come into the TV receiver and possibly blow it. The correct way would be to use a diplexer (with sufficient Tx VHF to Rx UHF isolation) that will survive the power of the VHF and separate the signals in frequency.
Good luck,
Alan.
Bergman
27 Nov 2002
In a word - no
These splitters are really not a good idea.
It seems to me a completely unecessary risk to compromise VHF performance which is an essential safety tool only to save the trouble of hanging a temporary TV aerial in the rigging.
If good TV reception is important (and I have sailed with children so I understand its value) then its worth fitting a proper TV aerial with an amplifier built into aerial base.
Don't go for an amp that is on the TV end of the coax - that just amplifies the noise.
dmayes
22 Mar 2005
Berkshire
www.drmsom.com
You will notice that most fixed TV aerials are horizontal whereas the VHF is vertical. VHF is just over one meter in length for a quarter wave aerial while the TV ones are only about 20 cm long. The TV ones that look like a ladder are actually very positional and have to be pointed at the transmitter as they are like radio telescopes and get a stronger signal from a very defined angle. So the answer is "no", don't use a splitter, use one of the indoor amplified TV aerials from Tandy as you can position it where you want. Remember that it is also difficult keeping the aerial still in a beat to wndward, you need a really competent crewmember to keep it pointing at the station, good practise for "MOB" pointing though.
pappaecho
13 Oct 2004
S. Hampshire
I paid a quid for a "caravan TV aerial" at a local boot sale. It has two enormous rubber skickers which stick to the side of the cabin, and a reasonable array of dipoles to give a good TV picture. It folds away, into a small space, and works in both UK (PAl) and France (Secam) and we have had very interesting communications from outer space, specially late on a Saturday night
