haemophilus
New Member
We have a Vetus 4.14 diesel engine. If we switch on the heater plugs for 10 seconds and then turn the ignition key to start the starter motor fails to engage. If we turn the switch on and off a couple of times it will engage and the engine then starts. The starter solenoid has been replaced, the starter motor overhauled and on the bench it spins up every time. The glow plugs have been checked and all show a resistance of less than 0.001 ohms. Disconnecting the heater plug feed means the starter engages every time and the engine will fire from cold after two to three seconds. The engine battery fitted went we purchased the boat had a capcaity 0f 60 AH and has been replaced with one that is new and is of 90 AH capacity. The ignition switch has been replaced and the problem remains. If we put a voltmeter across the starter battery before starting the start up process the reading is 12.9V. On switching on the heater plugs the voltage drops to less than 11.0V after about 10 seconds and we have the problem of the starter not spinning up. What am I missing as I am not an engineer or and electrician!!!
