Victor Azzopardi
In your case might well be. My boat has been launched in July ...new strainer all new through hulls and new piping. Will try hey hold of the original vetus cooler pressure cap and take it from there
In your case might well be. My boat has been launched in July ...new strainer all new through hulls and new piping. Will try hey hold of theIn your case might well be. My boat has been launched in July ...new strainer all new through hulls and new piping. Will try hey hold of the original vetus cooler pressure cap and take it from there
You should test for combustion gas in the coolant. Bubbling would often be cause by this. Essentially your checking for a failed head gasket or perhaps a crack that opens up when warm.
Caps likely 15 psi
Cooler will be the right size, its either dirty or the wire you removed was the governor max wire in which case your now over fuelling and creating heat
I presume this has been the case since you launched and not developed. The prop is clear of obstructions!?
