joe@greystones
Hi there
I have recently acquired an 1985 Westerly Merlin with it's original Bukh DV20 engine still installed and still running well..i think.
I have zero boat maintenance experience and have taken this on as a project. I have begun the long journey to refurbish her, starting with the removal of the old headlining and the updating of the electrical wiring/switch panel/engine control panel.
The existing wiring to/from the engine/ is to a VETUS MPA34 control panel which was installed by the previous owner.
The start switch and stop solenoid work, the rpm gauge gives an expected reading of about 1000 rpm at idle, but the battery voltage, engine temperature and oil pressure gauges show nothing.
The wiring behind is like a heap of spaghetti....and difficult for an amateur like me to decipher (even with the aid of the original wiring diagrams)...but it appears that some of the wires have been cut or connected to nothing in particular.
I would love to understand what wire does what so that I might begine to understand if it has been wired correctly and/or is giving the correct values and warnings.
Could it be the case that this equipment was simply incompatible with the engine in the first place and unable to read values from the engine temperature sensor, oil pressure sensor?
Any suggestions of where/who I should turn to? Is it simply a case of getting a marine engineer to examine it for me and show me whats what? Hate to give up. Anyone wired up something similar?
Regards
Joe Daly
Regards
Joe Daly
